跳转到主内容
HP Split x2 13-g210dx Battery Replacement
你所需要的
  1. HP Split x2 13-g210dx Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
  2. HP Split x2 13-g210dx Battery Replacement, Battery: 步骤 2 中的图像 1,1
    • Remove the three 6-mm Phillips #0 screws.
  3. HP Split x2 13-g210dx Battery Replacement: 步骤 3 中的图像 1,2 HP Split x2 13-g210dx Battery Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the white connector clip from the connector port using a sturdy tweezers.
  4. HP Split x2 13-g210dx Battery Replacement: 步骤 4 中的图像 1,2 HP Split x2 13-g210dx Battery Replacement: 步骤 4 中的图像 2,2
    • Lift the battery away from the device.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 19
总计 2,057
