跳转到主内容
HP Split x2 13-g210dx Back Panel Replacement
你所需要的
  1. HP Split x2 13-g210dx Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
结论
另外一个人完成了本指南。
一条评论
How do I put the felt cover back on?
Prince Phoenix - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 11
总计 406
