简介
If the audio is distorted through an external speaker or another peripheral device, then the Audio port is defective. Use this guide to access, remove, and replace your Audio port.
你所需要的
Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
Remove the four 4-mm Phillips #0 screws.
Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
