跳转到主内容
HP Split 13-r010dx Screen Replacement
你所需要的
  1. HP Split 13-r010dx Screen Replacement, Front and Back Panel: 步骤 1 中的图像 1,2 HP Split 13-r010dx Screen Replacement, Front and Back Panel: 步骤 1 中的图像 2,2
    • Locate the four screws at the bottom of the device. (Note that the keyboard attachment is missing from this device.)
    • Use a Philips head #0 screwdriver to remove each of the screws (Size: 4mm)
  2. HP Split 13-r010dx Screen Replacement: 步骤 2 中的图像 1,2 HP Split 13-r010dx Screen Replacement: 步骤 2 中的图像 2,2
    • Gently wedge the plastic opening tool in between where the display and back panel meet.
    • Slowly and gently apply force to the plastic opening tool in a downwards motion to loosen the front panel from the back panel.
    • Rotate the device so that the side is facing up and repeat the previous step for the sides.
    • Do NOT attempt to wedge the plastic opening tool on the bottom . Once the sides and top are loose you are ready to continue to the next step.
  3. HP Split 13-r010dx Screen Replacement: 步骤 3 中的图像 1,1
    • Gently and slowly pull the front and back panel away from each other (in opposite directions). ( Pulling them apart will not separate the two panels)
    • Only separate the panels by a few inches from each other so that there is room to separate the front and back panel in the next step. Proceed to the next step.
  4. HP Split 13-r010dx Screen Replacement: 步骤 4 中的图像 1,1
    • Hold the back panel firmly and pull the front panel upwards to completely separate the front panel from the back panel.
    • The device is now ready to be repaired or replacements installed.
  5. HP Split 13-r010dx Screen Replacement, Screen: 步骤 5 中的图像 1,3 HP Split 13-r010dx Screen Replacement, Screen: 步骤 5 中的图像 2,3 HP Split 13-r010dx Screen Replacement, Screen: 步骤 5 中的图像 3,3
    • Use the PH1 screwdriver to remove eleven 4mm Phillips screws.
  6. HP Split 13-r010dx Screen Replacement: 步骤 6 中的图像 1,2 HP Split 13-r010dx Screen Replacement: 步骤 6 中的图像 2,2
    • Unscrew the two 2mm zero insertion force connectors. Slide aside the white wires to properly unscrew.
  7. HP Split 13-r010dx Screen Replacement: 步骤 7 中的图像 1,3 HP Split 13-r010dx Screen Replacement: 步骤 7 中的图像 2,3 HP Split 13-r010dx Screen Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to pull up the yellow colored display cable connector.
    • Pull it to the direction of the cable.
  8. HP Split 13-r010dx Screen Replacement: 步骤 8 中的图像 1,1
    • Glue is attached at the edges. Apply force to the sides of the tablet. Separate the digitizer from the body of the tablet.
    • Replace the old screen with a new one.
    • If your screen is broken or damaged, use caution when pulling the screen from the tablet to avoid self harm.
结论
另外一个人完成了本指南。
一条评论
Hello… How to know if it is the digitizer or the screen that is broken? .. thanks
Martin Sala - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 597
