简介
This guide will instruct you on how to remove and replace the Wifi Adapter. Replacement of the wifi adapter may be necessary if the device cannot connect to the internet.
你所需要的
Turn off and unplug the laptop.
Flip over the laptop so that the bottom backplate is exposed.
在这个步骤中使用的工具:Tweezers$4.99
With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
With the screws removed, disconnect the 3 wires connected to the battery.
即将完成!
结论
