跳转到主内容
HP Spectre x360 13t-4000 Speakers Replacement
你所需要的
  1. HP Spectre x360 13t-4000 Speakers Replacement, Bottom Cover: 步骤 1 中的图像 1,2 HP Spectre x360 13t-4000 Speakers Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Speakers Replacement: 步骤 2 中的图像 1,2 HP Spectre x360 13t-4000 Speakers Replacement: 步骤 2 中的图像 2,2
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Speakers Replacement: 步骤 3 中的图像 1,3 HP Spectre x360 13t-4000 Speakers Replacement: 步骤 3 中的图像 2,3 HP Spectre x360 13t-4000 Speakers Replacement: 步骤 3 中的图像 3,3
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 Speakers Replacement, Battery: 步骤 4 中的图像 1,3 HP Spectre x360 13t-4000 Speakers Replacement, Battery: 步骤 4 中的图像 2,3 HP Spectre x360 13t-4000 Speakers Replacement, Battery: 步骤 4 中的图像 3,3
    • With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
    • With the screws removed, disconnect the 3 wires connected to the battery.
    • Tweezers may be needed to remove the wires.
  5. HP Spectre x360 13t-4000 Speakers Replacement, Speakers: 步骤 5 中的图像 1,3 HP Spectre x360 13t-4000 Speakers Replacement, Speakers: 步骤 5 中的图像 2,3 HP Spectre x360 13t-4000 Speakers Replacement, Speakers: 步骤 5 中的图像 3,3
    • With the backplate and battery removed from the device, remove the three 2mm screws using the Phillips #0 screwdriver.
  6. HP Spectre x360 13t-4000 Speakers Replacement: 步骤 6 中的图像 1,2 HP Spectre x360 13t-4000 Speakers Replacement: 步骤 6 中的图像 2,2
    • With all three screws removed, remove the speaker assembly from the device.
结论
Michael Bisbano
于03/18/19注册
88 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 1,280
