简介
This guide will instruct you on how to remove the bottom cover. The removal of the bottom cover is necessary in order to replace any other components of the laptop.
你所需要的
Turn off and unplug the laptop.
Flip over the laptop so that the bottom backplate is exposed.
另外一个人完成了本指南。
一条评论
Any idea for previous model like acxxxx? The 5mm screw aren't visible, bit it's like if they are there. The corners won't come out. Is the screws hidden deep under the rubber pad? Removed the rubber, do we need to somehow remove the plastic part on which the rubber pad are glued? If so how? They seems to be glued on
