跳转到主内容
HP Spectre x360 13-ac023dx WiFi Card Replacement
你所需要的
  1. HP Spectre x360 13-ac023dx WiFi Card Replacement, Battery: 步骤 1 中的图像 1,2 HP Spectre x360 13-ac023dx WiFi Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre x360 13-ac023dx WiFi Card Replacement: 步骤 2 中的图像 1,3 HP Spectre x360 13-ac023dx WiFi Card Replacement: 步骤 2 中的图像 2,3 HP Spectre x360 13-ac023dx WiFi Card Replacement: 步骤 2 中的图像 3,3
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre x360 13-ac023dx WiFi Card Replacement: 步骤 3 中的图像 1,2 HP Spectre x360 13-ac023dx WiFi Card Replacement: 步骤 3 中的图像 2,2
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectre x360 13-ac023dx WiFi Card Replacement, WiFi Card: 步骤 4 中的图像 1,1
    • Locate the WiFi card.
  5. HP Spectre x360 13-ac023dx WiFi Card Replacement: 步骤 5 中的图像 1,1
    • Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
  6. HP Spectre x360 13-ac023dx WiFi Card Replacement: 步骤 6 中的图像 1,2 HP Spectre x360 13-ac023dx WiFi Card Replacement: 步骤 6 中的图像 2,2
    • Once the screw is removed, raise the WiFi card and slide it out from the motherboard.
结论
Jonathan
于10/21/19注册
486 声望
创作了4篇指南
团队
UMass Dartmouth, Team S1-G6, Botvin Fall 2019 UMass Dartmouth, Team S1-G6, Botvin Fall 2019 的会员
UMASSD-BOTVIN-F19S1G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 13
总计 1,817
