跳转到主内容
HP Spectre x360 13-ac023dx Motherboard Replacement
你所需要的
  1. HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 2 中的图像 1,3 HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 2 中的图像 2,3 HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 2 中的图像 3,3
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 3 中的图像 1,2 HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectre x360 13-ac023dx Motherboard Replacement, Fan: 步骤 4 中的图像 1,1
    • Locate the Cooling Fan in the device.
  5. HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 5 中的图像 1,2 HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 5 中的图像 2,2
    • Use the Phillips #000 screwdriver to remove the 3mm screws holding the fan in place.
    • Remove the wires connecting to the motherboard, using the iFixit opening tool.
    • The iFixit Opening Tool is not required, but recommended
  6. HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the Cooling Fan.
  7. HP Spectre x360 13-ac023dx Motherboard Replacement, WiFi Card: 步骤 7 中的图像 1,1
    • Locate the WiFi card.
  8. HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 8 中的图像 1,1
    • Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
  9. HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 9 中的图像 1,2 HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 9 中的图像 2,2
    • Once the screw is removed, raise the WiFi card and slide it out from the motherboard.
  10. HP Spectre x360 13-ac023dx Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,1
    • Ensure that all other components which were previously removed are not longer attached.
  11. HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 11 中的图像 1,3 HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 11 中的图像 2,3 HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 11 中的图像 3,3
    • Disconnect the wires which connect the motherboard to the rest of the components.
    • The black and red wire can be removed by pulling the wire upwards.
  12. HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 12 中的图像 1,3 HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 12 中的图像 2,3 HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 12 中的图像 3,3
    • Use the Phillips #000 screwdriver to remove the three 3.5 mm screws which keep the motherboard in place.
  13. HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 13 中的图像 1,2 HP Spectre x360 13-ac023dx Motherboard Replacement: 步骤 13 中的图像 2,2
    • Carefully lift and remove the motherboard.
结论
Jonathan
于10/21/19注册
486 声望
创作了4篇指南
团队
UMass Dartmouth, Team S1-G6, Botvin Fall 2019 UMass Dartmouth, Team S1-G6, Botvin Fall 2019 的会员
UMASSD-BOTVIN-F19S1G6
3 名成员
创作了6篇指南
一条评论
Can I get ho spectre x360 motherboard to buy from your end?
Immanuel - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 49
总计 3,412
