跳转到主内容
HP Spectre x360 13-4103dx Wi-Fi Card Replacement
你所需要的
  1. HP Spectre x360 13-4103dx Wi-Fi Card Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Turn off your laptop before you start.
    • Flip your laptop so the bottom is facing upwards.
  2. HP Spectre x360 13-4103dx Wi-Fi Card Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #0 to remove the screws that hold the back panel down.
  3. HP Spectre x360 13-4103dx Wi-Fi Card Replacement: 步骤 3 中的图像 1,1
    • Use an opening tool to remove the back panel.
    • Be careful when applying force to the panel so the components and the panel are not damaged.
    • Try to start at a corner or a place with the most room to slide under the panel.
  4. HP Spectre x360 13-4103dx Wi-Fi Card Replacement, Wi-Fi Card: 步骤 4 中的图像 1,1
    • Remove the single screw from the Wi-Fi card using a Phillips #0 screwdriver.
  5. HP Spectre x360 13-4103dx Wi-Fi Card Replacement: 步骤 5 中的图像 1,1
    • Pull the Wi-Fi card out of the computer.
结论
Andrew Medeiros
于10/25/21注册
511 声望
创作了4篇指南
团队
UMass Dartmouth, Team 3-6, Sinclaire Fall 2021 UMass Dartmouth, Team 3-6, Sinclaire Fall 2021 的会员
UMASSD-SINCLAIRE-F21S3G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 122
