跳转到主内容
简介
The vent fan keeps the laptop from overheating so the laptop needs to be turned off during this procedure.
  1. Using the Torx T5 screwdriver, remove  the eight 8 mm screws on the bottom case of the laptop. Using the Torx T5 screwdriver, remove  the eight 8 mm screws on the bottom case of the laptop.
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. Pry up one corner of the bottom case  with a spudger. Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. Remove the strip of black electrical tape. Pull the tape away from the vent fan. Pull gently, as the tape is easy to rip.
    • Remove the strip of black electrical tape.
    • Pull the tape away from the vent fan.
    • Pull gently, as the tape is easy to rip.
  4. Using a Phillips #0 screwdriver, remove the two 40 mm screws securing the fan assembly to the motherboard. Using a Phillips #0 screwdriver, remove the two 40 mm screws securing the fan assembly to the motherboard.
    • Using a Phillips #0 screwdriver, remove the two 40 mm screws securing the fan assembly to the motherboard.
  5. Using tweezers, disconnect the wire connection between the laptop and the  vent fan. Using tweezers, disconnect the wire connection between the laptop and the  vent fan. Using tweezers, disconnect the wire connection between the laptop and the  vent fan.
    • Using tweezers, disconnect the wire connection between the laptop and the vent fan.
  6. Remove the vent fan.
    • Remove the vent fan.
结论
Cayce Stewart
于2019年01月16日注册
725 信誉积分
创作了6篇指南
Any idea what model# the fan is?
ayekay - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 12
总计 149
