当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Pry up one corner of the bottom case with a spudger.
Work the spudger around the edges, making your way towards the bottom of the laptop.
Remove the bottom case.
Do not disconnect the cable connector shown in the red box.
The speaker cable may be attached to the battery with black electrical tape. If so, remove the tape.
Move the cable clear of the battery.
Do not disconnect the cable connector located in the red box.
Use tweezers to remove the speaker cable from the groove attached to the battery.
Push the cable to the side so it does not get in the way of the battery removal.
To release the ribbon cable, flip up the white tab on the connector 90 degrees.
Pull the ribbon cable out of the connector.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
