简介
The laptop needs to be turned off during this procedure. The battery will need to be removed for this procedure and you or your laptop can be damaged if the battery is disconnected while the power is on. All SD cards need to be ejected before replacing the SD card reader.
你所需要的
Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
Remove the six 4 mm screws using a Phillips #000 screwdriver.
The SD Card Port is located in the red box.
Remove the one PH0 30 mm screw circled in red.
