跳转到主内容
HP Spectre 13-4002dx Heat Sink Replacement
你所需要的
  1. HP Spectre 13-4002dx Heat Sink Replacement, Bottom Case: 步骤 1 中的图像 1,2 HP Spectre 13-4002dx Heat Sink Replacement, Bottom Case: 步骤 1 中的图像 2,2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Heat Sink Replacement: 步骤 2 中的图像 1,2 HP Spectre 13-4002dx Heat Sink Replacement: 步骤 2 中的图像 2,2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Heat Sink Replacement, Heat Sink: 步骤 3 中的图像 1,3 HP Spectre 13-4002dx Heat Sink Replacement, Heat Sink: 步骤 3 中的图像 2,3 HP Spectre 13-4002dx Heat Sink Replacement, Heat Sink: 步骤 3 中的图像 3,3
    • Remove the tape outlined in red.
    • The tape can tear easily.
  4. HP Spectre 13-4002dx Heat Sink Replacement: 步骤 4 中的图像 1,2 HP Spectre 13-4002dx Heat Sink Replacement: 步骤 4 中的图像 2,2
    • Remove the four 3 mm screws using a Phillips #0 screwdriver.
  5. HP Spectre 13-4002dx Heat Sink Replacement: 步骤 5 中的图像 1,1
    • Remove the heat sink from the laptop.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 256
