跳转到主内容
HP Spectre 13-4002dx Display Replacement
你所需要的
  1. HP Spectre 13-4002dx Display Replacement, Motherboard: 步骤 1 中的图像 1,3 HP Spectre 13-4002dx Display Replacement, Motherboard: 步骤 1 中的图像 2,3 HP Spectre 13-4002dx Display Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Remove the black tape from the motherboard.
    • Remove five screws using the Phillips #00 screwdriver that holds the motherboard in place.
    • Disconnect five ribbon cables, three power cables, and two wifi antennas from the motherboard.
    • Gently lift the motherboard out of the computer. Be careful to not to disturb the CPU fan.
    • Do not bend the motherboard.
  2. HP Spectre 13-4002dx Display Replacement, Display: 步骤 2 中的图像 1,1
    • Remove four screws connecting the screen to the laptop case with the Phillips #00 screwdriver.
  3. HP Spectre 13-4002dx Display Replacement: 步骤 3 中的图像 1,2 HP Spectre 13-4002dx Display Replacement: 步骤 3 中的图像 2,2
    • Bring the laptop screen to a 270 degree angle from the base.
    • Pull the display towards you for the display to pop out of the base.
    • Gently remove the display to ensure that the cables do not get caught on the case.
  4. HP Spectre 13-4002dx Display Replacement: 步骤 4 中的图像 1,2 HP Spectre 13-4002dx Display Replacement: 步骤 4 中的图像 2,2
    • Remove the rubber seal around display with the opening tool.
    • Pry the display off.
    • Be careful while removing the display as it could snap and cause damage and/or injury. Be careful to not cut any wiring between the screen and its casing.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 437
