本指南有最近更改,您可查看未经巡查的最新版本。
简介
The laptop needs to be turned off during this procedure. Disconnecting the battery while the laptop is powered on may hurt you or damage your laptop.
你所需要的
Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
Remove the six 4 mm screws using a Phillips #000 screwdriver.
即将完成!
结论
