跳转到主内容
HP Spectre 13-4002dx Battery Replacement
你所需要的
  1. HP Spectre 13-4002dx Battery Replacement, Bottom Case: 步骤 1 中的图像 1,2 HP Spectre 13-4002dx Battery Replacement, Bottom Case: 步骤 1 中的图像 2,2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Battery Replacement: 步骤 2 中的图像 1,2 HP Spectre 13-4002dx Battery Replacement: 步骤 2 中的图像 2,2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Battery Replacement, Battery: 步骤 3 中的图像 1,3 HP Spectre 13-4002dx Battery Replacement, Battery: 步骤 3 中的图像 2,3 HP Spectre 13-4002dx Battery Replacement, Battery: 步骤 3 中的图像 3,3
    • Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
    • Remove the six 4 mm screws using a Phillips #000 screwdriver.
  4. HP Spectre 13-4002dx Battery Replacement: 步骤 4 中的图像 1,3 HP Spectre 13-4002dx Battery Replacement: 步骤 4 中的图像 2,3 HP Spectre 13-4002dx Battery Replacement: 步骤 4 中的图像 3,3
    • Do not disconnect the cable connector shown in the red box.
    • The speaker cable may be attached to the battery with black electrical tape. If so, remove the tape.
    • Move the cable clear of the battery.
  5. HP Spectre 13-4002dx Battery Replacement: 步骤 5 中的图像 1,2 HP Spectre 13-4002dx Battery Replacement: 步骤 5 中的图像 2,2
    • Do not disconnect the cable connector located in the red box.
    • Use tweezers to remove the speaker cable from the groove attached to the battery.
    • Push the cable to the side so it does not get in the way of the battery removal.
  6. HP Spectre 13-4002dx Battery Replacement: 步骤 6 中的图像 1,3 HP Spectre 13-4002dx Battery Replacement: 步骤 6 中的图像 2,3 HP Spectre 13-4002dx Battery Replacement: 步骤 6 中的图像 3,3
    • Disconnect the battery cable connector by sliding it out of the socket.
    • Move the battery out of the way if you need more room to disconnect the power cable.
  7. HP Spectre 13-4002dx Battery Replacement: 步骤 7 中的图像 1,1
    • Carefully remove the battery.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 1,245
