跳转到主内容
HP Spectre 13-3010dx Fan Replacement
你所需要的
  1. HP Spectre 13-3010dx Fan Replacement, Removal of the Back Case: 步骤 1 中的图像 1,2 HP Spectre 13-3010dx Fan Replacement, Removal of the Back Case: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Put on Anti Static Wrist Strap.
    • It is always a good idea to ground yourself when working with electronics to prevent static buildup. You wear this strap to protect you and your device from accidental electrostatic discharge (ESD) damage during repairs.]
    • Flip Computer Upside down.
    • Unscrew the eight 3.3mm black screws on the back casing with the T4 Torx Screwdriver.
  2. HP Spectre 13-3010dx Fan Replacement: 步骤 2 中的图像 1,2 HP Spectre 13-3010dx Fan Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to lift the back case off.
    • Use the plastic opening tools first; metal spudgers can damage your device.
  3. HP Spectre 13-3010dx Fan Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the six 2.0mm silver screws and the two 3.2 mm black screws using the PH00 Phillips Screw Head.
  4. HP Spectre 13-3010dx Fan Replacement: 步骤 4 中的图像 1,1
    • Gently unplug from CONO851 plug, using the plastic opening tool.
  5. HP Spectre 13-3010dx Fan Replacement: 步骤 5 中的图像 1,2 HP Spectre 13-3010dx Fan Replacement: 步骤 5 中的图像 2,2
    • Gently lift up the battery and remove using the plastic opening tools.
  6. HP Spectre 13-3010dx Fan Replacement, Fan: 步骤 6 中的图像 1,1
    • Unscrew three 2.0 mm screws using the Phillips Head #0
  7. HP Spectre 13-3010dx Fan Replacement: 步骤 7 中的图像 1,1
    • Disconnect the plug.
  8. HP Spectre 13-3010dx Fan Replacement: 步骤 8 中的图像 1,1
    • Remove the fan.
结论
6等其他人完成本指南。
2条评论
Why did you physically remove the battery? It seems like unplugging the battery’s CONO851 plug would be good enough? It’s funny, even in the photo where you remove the fan, the battery is still there.
tshong - 回复
I replaced the fan in my computer. As tshong said, I did not have to remove the battery. Just unplugged it then skipped steps 3 and 5. and voila.
Trach Nguyen - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 3,431
