跳转到主内容
HP Spectre 13-3010dx Battery Replacement
你所需要的
  1. HP Spectre 13-3010dx Battery Replacement, Removal of the Back Case: 步骤 1 中的图像 1,2 HP Spectre 13-3010dx Battery Replacement, Removal of the Back Case: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Put on Anti Static Wrist Strap.
    • It is always a good idea to ground yourself when working with electronics to prevent static buildup. You wear this strap to protect you and your device from accidental electrostatic discharge (ESD) damage during repairs.]
    • Flip Computer Upside down.
    • Unscrew the eight 3.3mm black screws on the back casing with the T4 Torx Screwdriver.
  2. HP Spectre 13-3010dx Battery Replacement: 步骤 2 中的图像 1,2 HP Spectre 13-3010dx Battery Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to lift the back case off.
    • Use the plastic opening tools first; metal spudgers can damage your device.
  3. HP Spectre 13-3010dx Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the six 2.0mm silver screws and the two 3.2 mm black screws using the PH00 Phillips Screw Head.
  4. HP Spectre 13-3010dx Battery Replacement: 步骤 4 中的图像 1,1
    • Gently unplug from CONO851 plug, using the plastic opening tool.
  5. HP Spectre 13-3010dx Battery Replacement: 步骤 5 中的图像 1,2 HP Spectre 13-3010dx Battery Replacement: 步骤 5 中的图像 2,2
    • Gently lift up the battery and remove using the plastic opening tools.
结论
11等其他人完成本指南。
4条评论
Good Job presenting the steps. I need to find a battery for my hp 13-3010dx ultrabook. Any ideas where one can be purchased.
Dawson Wilke - 回复
Hi Dawson Wilke, the battery seems has two kinds of interface, I suggest you take out your old battery check the battery model and product parameter, such as voltage and current as well as the interface, then search the right battery from online store. If you confuse on it, I am here willing to help you.
julie -
Hi i did this found a battery online and did an installation of the replacement. Unfortunately it is not an original hp battery as none are available. However the issue I am having is that the new battery is not being detected. Any recommendations?
Leah Cleghorn - 回复
Cosmas Dorah - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 15
总计 18,946
