跳转到主内容
HP Spectre 13 4003dx x360 Touchpad Replacement
你所需要的
  1. HP Spectre 13 4003dx x360 Touchpad Replacement, Battery: 步骤 1 中的图像 1,2 HP Spectre 13 4003dx x360 Touchpad Replacement, Battery: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Turn the computer upside down.
    • Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
    • Make sure to use the magnetic project mat to help you keep track of the small screws.
  2. HP Spectre 13 4003dx x360 Touchpad Replacement: 步骤 2 中的图像 1,2 HP Spectre 13 4003dx x360 Touchpad Replacement: 步骤 2 中的图像 2,2
    • Use an opening tool to pry up and loosen the back case from the laptop.
    • If the back case doesn't loosen easily, there may be screws hidden underneath the rubber feet. Carefully pry a foot up and remove any hidden screws.
    • Remove the back case.
  3. HP Spectre 13 4003dx x360 Touchpad Replacement: 步骤 3 中的图像 1,2 HP Spectre 13 4003dx x360 Touchpad Replacement: 步骤 3 中的图像 2,2
    • Remove the four 2mm Phillips #00 screws securing the battery.
    • The screw locations are marked by small white arrows on the battery.
  4. HP Spectre 13 4003dx x360 Touchpad Replacement: 步骤 4 中的图像 1,3 HP Spectre 13 4003dx x360 Touchpad Replacement: 步骤 4 中的图像 2,3 HP Spectre 13 4003dx x360 Touchpad Replacement: 步骤 4 中的图像 3,3
    • Peel off the adhesive on the left side of the battery holding the speaker wire down.
    • Move the battery slightly to gain access to the battery plug, located on the left edge of the battery.
    • Carefully unplug the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the battery.
    • It is normal for your battery to flex and bend a bit where the wider section meets the narrower section.
  5. HP Spectre 13 4003dx x360 Touchpad Replacement, Touchpad: 步骤 5 中的图像 1,2 HP Spectre 13 4003dx x360 Touchpad Replacement, Touchpad: 步骤 5 中的图像 2,2
    • Using a plastic opening tool, lift the locking bar on the trackpad ZIF connector.
    • Gently pull the cable out.
  6. HP Spectre 13 4003dx x360 Touchpad Replacement: 步骤 6 中的图像 1,3 HP Spectre 13 4003dx x360 Touchpad Replacement: 步骤 6 中的图像 2,3 HP Spectre 13 4003dx x360 Touchpad Replacement: 步骤 6 中的图像 3,3
    • Using the PH00 Screwdriver, remove the five 2.0 mm screws indicated in the picture.
  7. HP Spectre 13 4003dx x360 Touchpad Replacement: 步骤 7 中的图像 1,2 HP Spectre 13 4003dx x360 Touchpad Replacement: 步骤 7 中的图像 2,2
    • Using a plastic opening tool, carefully lift up on the lower center metal piece of the touchpad.
    • Using both hands, gently lift up on the touchpad until it is completely removed.
    • If you are uncomfortable using the plastic opening tool, both hands can be used to remove the touchpad.
结论
2等其他人完成本指南。
Ethan Plumer
于01/29/18注册
605 声望
创作了2篇指南
团队
USF Tampa, Team S5-G4, Passmore Spring 2018 USF Tampa, Team S5-G4, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S5G4
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 32
总计 3,879
