你所需要的
这个步骤还没有翻译 帮忙翻译一下
Turn the computer upside down.
Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
这个步骤还没有翻译 帮忙翻译一下
Peel off the adhesive on the left side of the battery holding the speaker wire down.
Move the battery slightly to gain access to the battery plug, located on the left edge of the battery.
Carefully unplug the battery by pulling the connector towards the battery.
Remove the battery.
6等其他人完成本指南。
5条评论
Thank you! iFixit repair kit made getting the screws out easy. Now have a renewed laptop ready with 6 plus hours of battery life.
Tutoriel parfait, excepté peut-être qu’un double-fil côté droit de la batterie doit être libéré avant de sortir la batterie.
Bravo et merci, ça m’a tout simplement permis de me dépanner seul.
The official HP Manual (http://h10032.www1.hp.com/ctg/Manual/c04...) mentions using Torx T5 to remove the bottom cover.
Thanks! I will correct the step with the right screw size.
