简介
If your HP Spectre x360 13-ac023dx laptop is overheating or is having trouble charging properly, use this guide and follow it to replace the battery.
你所需要的
5等其他人完成本指南。
4条评论
The overall procedure is ok, however as others commented instructions on how to remove the feet would be helpful. I tried a heat gun to help loosen the glue, however that just melted the feat. Overall go the job done, but 2 out of the 4 feet were destroyed in the process.
Also in my case there were no screws under the top or bottom feet, so I could have probably removed the cover without removing the feet.
I think HP quietly refreshed the internals of this laptop or something, because despite appearing externally identical to the laptop shown in the pictures, mine has a smaller main board and differently sized battery. so you should open yours up and check before ordering the battery. mine has the PK03XL. this is double annoying because I was repairing this one for a friend, and she's the one who ordered the battery.
just finished my repair of my w-013 version. good to know that the top two feet have screws underneath them - small risk of denting the bottom cover if you're not gentle. also, the cable is slightly too long to fit neatly in the battery receptacle - it required some jamming that i'll probably be concerned about for a while.
This guide was helpful but my bottom two feet didn't have screws. I used a T4 instead of T5 and for the Phillips a T0 and a T1.
The battery had two metal stickers on it under the bottom feet so I put them on the replacement battery in the same place.
My model is 13-ac033dx
