跳转到主内容
HP Slate 8 Pro Speakers Replacement
你所需要的
  1. HP Slate 8 Pro Speakers Replacement, Remove back cover: 步骤 1 中的图像 1,1
    • Use plastic opening tool to pry back panel off.
  2. HP Slate 8 Pro Speakers Replacement, Detach IO Board from system: 步骤 2 中的图像 1,2 HP Slate 8 Pro Speakers Replacement, Detach IO Board from system: 步骤 2 中的图像 2,2
    • Remove the orange and yellow ribbon cables.
    • detach the screws along the IO board
  3. HP Slate 8 Pro Speakers Replacement, Remove the IO board and the speakers: 步骤 3 中的图像 1,1
    • Remove the IO board and the speakers circuit. Note that they are held together.
  4. HP Slate 8 Pro Speakers Replacement, Detach the speakers from the IO board.: 步骤 4 中的图像 1,1
    • The tablet has two speakers. Each speaker is located to both sides of the IO board.
    • Detach the speakers from the cables that connect the speakers and the IO board. You will find more details in step 5 and 6.
  5. HP Slate 8 Pro Speakers Replacement, Remove the wires of the speakers from the IO board.: 步骤 5 中的图像 1,1
    • To remove the cables that connect the speakers and the IO board, apply a subtle pressure to pull the cable out.
  6. HP Slate 8 Pro Speakers Replacement, Replace your speakers with the new parts: 步骤 6 中的图像 1,2 HP Slate 8 Pro Speakers Replacement, Replace your speakers with the new parts: 步骤 6 中的图像 2,2
    • Once you detach the speakers from the IO board, you should have three pieces as shown.
    • You are ready to replace the speakers.
结论
另外一个人完成了本指南。
Jose Revelo
于09/23/14注册
305 声望
创作了3篇指南
团队
USF Tampa, Team 9-4, Blackwell Fall 2014 USF Tampa, Team 9-4, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S9G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 431
