跳转到主内容
HP Slate 8 Pro Microphone Replacement
你所需要的
  1. HP Slate 8 Pro Microphone Replacement, Remove the back cover: 步骤 1 中的图像 1,1
    • Before opening your device, turn off the tablet. If you are unsure whether the tablet is off or in Hibernation, turn the tablet on, and then shut it down through the operating system.
    • Unplug your tablet from any power supply
    • Remove all external devices.
    • Remove back cover with plastic tools to avoid scratching the screen.
  2. HP Slate 8 Pro Microphone Replacement, Remove screws: 步骤 2 中的图像 1,1
    • Remove all screws from the sides of the battery
  3. HP Slate 8 Pro Microphone Replacement, Disconnect the battery cable: 步骤 3 中的图像 1,1
    • Disconnect the battery cable from the system board.
    • Use a little bit of pressure to remove the cable.
  4. HP Slate 8 Pro Microphone Replacement, Remove ZIF connector: 步骤 4 中的图像 1,1
    • Release the ZIF connector to which the microphone cable is attached
  5. HP Slate 8 Pro Microphone Replacement, Remove the  microphone: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove microphone from panel using tweezers
    • Add your new microphone
结论
Claudia
于08/31/14注册
252 声望
创作了2篇指南
团队
USF Tampa, Team 9-4, Blackwell Fall 2014 USF Tampa, Team 9-4, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S9G4
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 502
