跳转到主内容
HP Slate 7 Plus 4200US Tablet Cover Replacement
你所需要的
  1. HP Slate 7 Plus 4200US Tablet Cover Replacement, Tablet Cover: 步骤 1 中的图像 1,1
    • Turn off the tablet and disconnect the power and all external devices from the tablet.
    • Position the tablet with the display panel down and the right side toward you.
    • Carefully insert a plastic opening tool between the tablet cover and display panel assembly, separating the two components. The first insertion point should be between the power button and the volume buttons.
  2. HP Slate 7 Plus 4200US Tablet Cover Replacement: 步骤 2 中的图像 1,2 HP Slate 7 Plus 4200US Tablet Cover Replacement: 步骤 2 中的图像 2,2
    • Slide the tool around the perimeter of the tablet until the edge of the cover is completely separated from the display panel assembly.
  3. HP Slate 7 Plus 4200US Tablet Cover Replacement: 步骤 3 中的图像 1,3 HP Slate 7 Plus 4200US Tablet Cover Replacement: 步骤 3 中的图像 2,3 HP Slate 7 Plus 4200US Tablet Cover Replacement: 步骤 3 中的图像 3,3
    • Pry open the back cover to take it off.
结论
另外一个人完成了本指南。
Jessica Andrade
于10/04/16注册
860 声望
创作了7篇指南
团队
USF Tampa, Team 3-1, Sullivan Fall 2016 USF Tampa, Team 3-1, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S3G1
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 282
