跳转到主内容
HP Slate 7 Plus 4200US Battery Replacement
你所需要的
  1. HP Slate 7 Plus 4200US Battery Replacement, Tablet Cover: 步骤 1 中的图像 1,1
    • Turn off the tablet and disconnect the power and all external devices from the tablet.
    • Position the tablet with the display panel down and the right side toward you.
    • Carefully insert a plastic opening tool between the tablet cover and display panel assembly, separating the two components. The first insertion point should be between the power button and the volume buttons.
  2. HP Slate 7 Plus 4200US Battery Replacement: 步骤 2 中的图像 1,2 HP Slate 7 Plus 4200US Battery Replacement: 步骤 2 中的图像 2,2
    • Slide the tool around the perimeter of the tablet until the edge of the cover is completely separated from the display panel assembly.
  3. HP Slate 7 Plus 4200US Battery Replacement: 步骤 3 中的图像 1,3 HP Slate 7 Plus 4200US Battery Replacement: 步骤 3 中的图像 2,3 HP Slate 7 Plus 4200US Battery Replacement: 步骤 3 中的图像 3,3
    • Pry open the back cover to take it off.
  4. HP Slate 7 Plus 4200US Battery Replacement, Battery: 步骤 4 中的图像 1,3 HP Slate 7 Plus 4200US Battery Replacement, Battery: 步骤 4 中的图像 2,3 HP Slate 7 Plus 4200US Battery Replacement, Battery: 步骤 4 中的图像 3,3
    • Disconnect the battery cables from the system board by desoldering them. See iFixit guide on how to solder.
    • The battery cables are soldered to the system in the following sequence, top to bottom: red, blue, green, yellow, black.
  5. HP Slate 7 Plus 4200US Battery Replacement: 步骤 5 中的图像 1,3 HP Slate 7 Plus 4200US Battery Replacement: 步骤 5 中的图像 2,3 HP Slate 7 Plus 4200US Battery Replacement: 步骤 5 中的图像 3,3
    • Insert a nylon spudger between the battery and the display panel assembly. Carefully pry the battery up and remove it from its place.
    • The battery is attached to the display panel assembly with double-sided adhesive. Make sure to firmly pull the battery.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
结论
另外一个人完成了本指南。
Jessica Andrade
于10/04/16注册
860 声望
创作了7篇指南
团队
USF Tampa, Team 3-1, Sullivan Fall 2016 USF Tampa, Team 3-1, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S3G1
3 名成员
创作了14篇指南
一条评论
Bonjour, où peut on trouver une batterie svp ?
C'est pour une tablette HP Slate7 Plus.
Merci pour votre aide.
Cordialement. Stéphane
dingo346 - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 14
总计 2,081
