跳转到主内容
加入维修社区 - 创建账户
HP Slate 7 Extreme 4400US Top Speaker Replacement
你所需要的
  1. HP Slate 7 Extreme 4400US Top Speaker Replacement, Back Cover: 步骤 1 中的图像 1,3 HP Slate 7 Extreme 4400US Top Speaker Replacement, Back Cover: 步骤 1 中的图像 2,3 HP Slate 7 Extreme 4400US Top Speaker Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Top Speaker Replacement, Top Speaker: 步骤 2 中的图像 1,2 HP Slate 7 Extreme 4400US Top Speaker Replacement, Top Speaker: 步骤 2 中的图像 2,2
    • Use the PH #000 phillips screw bit to remove one 5.0 mm screw.
  3. HP Slate 7 Extreme 4400US Top Speaker Replacement: 步骤 3 中的图像 1,3 HP Slate 7 Extreme 4400US Top Speaker Replacement: 步骤 3 中的图像 2,3 HP Slate 7 Extreme 4400US Top Speaker Replacement: 步骤 3 中的图像 3,3
    • Gently pull the entire black housing away from device.
    • Locate where the speakers' wires are connected to the motherboard.
    • Using wire cutters, sever the wires connecting the speaker to the motherboard. Strip the wires with a wire stripper and fashion the new wires to the old ones connected to the motherboard to reconnect.
    • You may use a soldering tool to disconnect the wires from the motherboard and to reconnect the new wires back to the motherboard.
结论
Brandon Ko
于09/15/16注册
698 声望
创作了6篇指南
团队
USF Tampa, Team 11-4, Blackwell Fall 2016 USF Tampa, Team 11-4, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S11G4
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 250
