跳转到主内容
HP Slate 7 Extreme 4400US Motherboard Replacement
你所需要的
  1. HP Slate 7 Extreme 4400US Motherboard  Replacement, Back Cover: 步骤 1 中的图像 1,3 HP Slate 7 Extreme 4400US Motherboard  Replacement, Back Cover: 步骤 1 中的图像 2,3 HP Slate 7 Extreme 4400US Motherboard  Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Motherboard  Replacement, Front-facing Camera: 步骤 2 中的图像 1,2 HP Slate 7 Extreme 4400US Motherboard  Replacement, Front-facing Camera: 步骤 2 中的图像 2,2
    • Use the PH #000 screw bit to remove the 5.0 mm screw holding down the top speaker to expose the front-facing camera.
  3. HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 3 中的图像 1,3 HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 3 中的图像 2,3 HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 3 中的图像 3,3
    • Pull back the tape holding the the front facing camera's connector strip to the device.
    • Use the nylon spudger to flip up the black retaining flap of the zero insertion force (ZIF) connector holding the strip in place.
    • Gently pull the camera's connecting strip out from the port.
  4. HP Slate 7 Extreme 4400US Motherboard  Replacement, Rear-Facing Camera: 步骤 4 中的图像 1,3 HP Slate 7 Extreme 4400US Motherboard  Replacement, Rear-Facing Camera: 步骤 4 中的图像 2,3 HP Slate 7 Extreme 4400US Motherboard  Replacement, Rear-Facing Camera: 步骤 4 中的图像 3,3
    • Pull back the tape holding the the camera's connector strip to the device.
  5. HP Slate 7 Extreme 4400US Motherboard  Replacement, Battery: 步骤 5 中的图像 1,3 HP Slate 7 Extreme 4400US Motherboard  Replacement, Battery: 步骤 5 中的图像 2,3 HP Slate 7 Extreme 4400US Motherboard  Replacement, Battery: 步骤 5 中的图像 3,3
    • Cut the battery connectors one by one using wire cutters.
    • Do not cut all the wires at the same time; you risk blowing up the battery or destroying the motherboard!
    • After disconnecting the battery, take the new battery and use wire connectors to connect to the motherboard.
    • You may use a soldering tool to disconnect the wires from the motherboard, and to also soldering the wires for the replacement battery onto the motherboard.
  6. HP Slate 7 Extreme 4400US Motherboard  Replacement, Charging port and Audio Jack Circuit Board: 步骤 6 中的图像 1,2 HP Slate 7 Extreme 4400US Motherboard  Replacement, Charging port and Audio Jack Circuit Board: 步骤 6 中的图像 2,2
    • Use the PH #000 phillips head screw driver to remove one 5.0 mm screw.
    • Move plastic housing and rear facing camera to expose silver bracket.
  7. HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 7 中的图像 1,2 HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 7 中的图像 2,2
    • Use the PH #000 phillips head screw driver to remove three 3.0mm screws. Remove the silver bracket.
  8. HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 8 中的图像 1,3 HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 8 中的图像 2,3 HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 8 中的图像 3,3
    • Grab the green circuit board and pull directly up to separate the glued down power strip.
    • Gently pull the circuit board out of its connector.
  9. HP Slate 7 Extreme 4400US Motherboard  Replacement, Top Speaker: 步骤 9 中的图像 1,2 HP Slate 7 Extreme 4400US Motherboard  Replacement, Top Speaker: 步骤 9 中的图像 2,2
    • Use the PH #000 phillips screw bit to remove one 5.0 mm screw.
  10. HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 10 中的图像 1,3 HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 10 中的图像 2,3 HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 10 中的图像 3,3
    • Gently pull the entire black housing away from device.
    • Locate where the speakers' wires are connected to the motherboard.
    • Using wire cutters, sever the wires connecting the speaker to the motherboard. Strip the wires with a wire stripper and fashion the new wires to the old ones connected to the motherboard to reconnect.
    • You may use a soldering tool to disconnect the wires from the motherboard and to reconnect the new wires back to the motherboard.
  11. HP Slate 7 Extreme 4400US Motherboard  Replacement, Bottom Speaker: 步骤 11 中的图像 1,2 HP Slate 7 Extreme 4400US Motherboard  Replacement, Bottom Speaker: 步骤 11 中的图像 2,2
    • Locate the wires connecting the bottom speaker to the motherboard. The wires will be running alongside the battery
    • Using the PH #000 screw bit, unscrew the two 5.0 mm screws holding the bottom speaker in place
  12. HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 12 中的图像 1,3 HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 12 中的图像 2,3 HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 12 中的图像 3,3
    • Using a pair of wire cutters, cut the wires connecting the speaker to the motherboard. Use a wire stripper to expose the wire to connect it with the wires of the new speaker.
    • You can also use a soldering tool to disconnect the wires from the motherboard and then connect the wires of the new speaker using the soldering tool.
  13. HP Slate 7 Extreme 4400US Motherboard  Replacement, Motherboard: 步骤 13 中的图像 1,1
    • Using the PH #000 philips head screw bit, unscrew the seven screws holding the motherboard in place. Those in red are 3.0mm in length
    • Those in orange are 5.0 mm in length
  14. HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 14 中的图像 1,2 HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 14 中的图像 2,2
    • Disconnect the press-fit connector from the mother board using the nylon spudger. Gently pry the connector up; it will pop out of place easily, so if its not coming out don't force it.
  15. HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 15 中的图像 1,3 HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 15 中的图像 2,3 HP Slate 7 Extreme 4400US Motherboard  Replacement: 步骤 15 中的图像 3,3
    • Gently pull the connector strips out of the motherboard. The motherboard is now disconnected.
结论
Brandon Ko
于09/15/16注册
698 声望
创作了6篇指南
团队
USF Tampa, Team 11-4, Blackwell Fall 2016 USF Tampa, Team 11-4, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S11G4
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 433
