跳转到主内容
HP Slate 7 Extreme 4400US Front-facing Camera Replacement
你所需要的
  1. HP Slate 7 Extreme 4400US Front-facing Camera Replacement, Back Cover: 步骤 1 中的图像 1,3 HP Slate 7 Extreme 4400US Front-facing Camera Replacement, Back Cover: 步骤 1 中的图像 2,3 HP Slate 7 Extreme 4400US Front-facing Camera Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Front-facing Camera Replacement, Front-facing Camera: 步骤 2 中的图像 1,2 HP Slate 7 Extreme 4400US Front-facing Camera Replacement, Front-facing Camera: 步骤 2 中的图像 2,2
    • Use the PH #000 screw bit to remove the 5.0 mm screw holding down the top speaker to expose the front-facing camera.
  3. HP Slate 7 Extreme 4400US Front-facing Camera Replacement: 步骤 3 中的图像 1,3 HP Slate 7 Extreme 4400US Front-facing Camera Replacement: 步骤 3 中的图像 2,3 HP Slate 7 Extreme 4400US Front-facing Camera Replacement: 步骤 3 中的图像 3,3
    • Pull back the tape holding the the front facing camera's connector strip to the device.
    • Use the nylon spudger to flip up the black retaining flap of the zero insertion force (ZIF) connector holding the strip in place.
    • Gently pull the camera's connecting strip out from the port.
结论
Brandon Ko
于09/15/16注册
698 声望
创作了6篇指南
团队
USF Tampa, Team 11-4, Blackwell Fall 2016 USF Tampa, Team 11-4, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S11G4
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 158
