跳转到主内容
加入维修社区 - 创建账户
HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement
你所需要的
  1. HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement, Back Cover: 步骤 1 中的图像 1,3 HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement, Back Cover: 步骤 1 中的图像 2,3 HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
    询问修复机器人
    添加评论
  2. HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement, Charging port and Audio Jack Circuit Board: 步骤 2 中的图像 1,2 HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement, Charging port and Audio Jack Circuit Board: 步骤 2 中的图像 2,2
    • Use the PH #000 phillips head screw driver to remove one 5.0 mm screw.
    • Move plastic housing and rear facing camera to expose silver bracket.
    询问修复机器人
    添加评论
  3. HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement: 步骤 3 中的图像 1,2 HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement: 步骤 3 中的图像 2,2
    • Use the PH #000 phillips head screw driver to remove three 3.0mm screws. Remove the silver bracket.
    询问修复机器人
    添加评论
  4. HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement: 步骤 4 中的图像 1,3 HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement: 步骤 4 中的图像 2,3 HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement: 步骤 4 中的图像 3,3
    • Use the nylon spudger to flip up the black retaining flap of the zero insertion force (ZIF) connector holding the strip in place.
    • Grab the green circuit board and pull directly up to separate the glued down power strip.
    • Gently pull the circuit board out of its connector.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Brandon Ko
于09/15/16注册
698 声望
创作了6篇指南
团队
USF Tampa, Team 11-4, Blackwell Fall 2016 USF Tampa, Team 11-4, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S11G4
4 名成员
创作了16篇指南
5指南评论
where can i get the part at?
cat jones - 回复 分享
Where do you even get the part at??
Mountiansurfer Gaming - 回复 分享
Where do I even get the part at???
Can you let us know where to get the replacement part from?
ypk77 - 回复 分享
This is completely useless information without a source for the shoddy HP part!
Brian Burke - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 42
总计 2,509
