跳转到主内容
HP Slate 7 Extreme 4400US Bottom Speaker Replacement
你所需要的
  1. HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Back Cover: 步骤 1 中的图像 1,3 HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Back Cover: 步骤 1 中的图像 2,3 HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Bottom Speaker: 步骤 2 中的图像 1,2 HP Slate 7 Extreme 4400US Bottom Speaker Replacement, Bottom Speaker: 步骤 2 中的图像 2,2
    • Locate the wires connecting the bottom speaker to the motherboard. The wires will be running alongside the battery
    • Using the PH #000 screw bit, unscrew the two 5.0 mm screws holding the bottom speaker in place
  3. HP Slate 7 Extreme 4400US Bottom Speaker Replacement: 步骤 3 中的图像 1,3 HP Slate 7 Extreme 4400US Bottom Speaker Replacement: 步骤 3 中的图像 2,3 HP Slate 7 Extreme 4400US Bottom Speaker Replacement: 步骤 3 中的图像 3,3
    • Locate where the speakers' wires are connected to the motherboard.
    • Using a pair of wire cutters, cut the wires connecting the speaker to the motherboard. Use a wire stripper to expose the wire to connect it with the wires of the new speaker.
    • You can also use a soldering tool to disconnect the wires from the motherboard and then connect the wires of the new speaker using the soldering tool.
结论
Brandon Ko
于09/15/16注册
698 声望
创作了6篇指南
团队
USF Tampa, Team 11-4, Blackwell Fall 2016 USF Tampa, Team 11-4, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S11G4
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 133
