跳转到主内容
HP Slate 7 Extreme 4400US Battery Replacement
你所需要的
  1. HP Slate 7 Extreme 4400US Battery Replacement, Back Cover: 步骤 1 中的图像 1,3 HP Slate 7 Extreme 4400US Battery Replacement, Back Cover: 步骤 1 中的图像 2,3 HP Slate 7 Extreme 4400US Battery Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Battery Replacement, Battery: 步骤 2 中的图像 1,3 HP Slate 7 Extreme 4400US Battery Replacement, Battery: 步骤 2 中的图像 2,3 HP Slate 7 Extreme 4400US Battery Replacement, Battery: 步骤 2 中的图像 3,3
    • Cut the battery connectors one by one using wire cutters.
    • Do not cut all the wires at the same time; you risk blowing up the battery or destroying the motherboard!
    • After disconnecting the battery, take the new battery and use wire connectors to connect to the motherboard.
    • You may use a soldering tool to disconnect the wires from the motherboard, and to also soldering the wires for the replacement battery onto the motherboard.
结论
Brandon Ko
于09/15/16注册
698 声望
创作了6篇指南
团队
USF Tampa, Team 11-4, Blackwell Fall 2016 USF Tampa, Team 11-4, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S11G4
4 名成员
创作了16篇指南
一条评论
Dude, do you have this part? HP Slate 7 Extreme 4400CA
https://www.worthpoint.com/worthopedia/o...
sivaldodomingos - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 12
总计 1,119
