跳转到主内容
HP Scanjet 4890 Scanner Glass Underside Cleaning
你所需要的
  1. HP Scanjet 4890 Scanner Glass Underside Cleaning, Unplug the cable to the scanner lid: 步骤 1 中的图像 1,2 HP Scanjet 4890 Scanner Glass Underside Cleaning, Unplug the cable to the scanner lid: 步骤 1 中的图像 2,2
    • In the manual the lid is known as the TMA - Transparent Materials Adapter
  2. HP Scanjet 4890 Scanner Glass Underside Cleaning, Remove the scanner lid: 步骤 2 中的图像 1,3 HP Scanjet 4890 Scanner Glass Underside Cleaning, Remove the scanner lid: 步骤 2 中的图像 2,3 HP Scanjet 4890 Scanner Glass Underside Cleaning, Remove the scanner lid: 步骤 2 中的图像 3,3
    • Open the lid 90° and lift straight up.
  3. HP Scanjet 4890 Scanner Glass Underside Cleaning, Turn upside down and remove the 4 PH#2 screws: 步骤 3 中的图像 1,1
    • 4x PH#2 3x8mm
  4. HP Scanjet 4890 Scanner Glass Underside Cleaning, Turn back so that the scanner glass is up: 步骤 4 中的图像 1,1
    • While the problem usually is to separate the top from the bottom, make sure that the top does not fall off while turning the scanner over, damaging the scanner glass.
  5. HP Scanjet 4890 Scanner Glass Underside Cleaning, Lift the top cover off the base: 步骤 5 中的图像 1,3 HP Scanjet 4890 Scanner Glass Underside Cleaning, Lift the top cover off the base: 步骤 5 中的图像 2,3 HP Scanjet 4890 Scanner Glass Underside Cleaning, Lift the top cover off the base: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    购买
    • The top has to be lifted straight up at the front and back at the same time.
    • I found Heavy-Duty Suction Cups (Pair) to work best, but due to the structure of the plastic they quickly loose their grip, so work fast.
    • Alternative: Lift the top cover in the back as little as possible and use Plastic Cards to work your way to the front until you are able to get a grip of the whole top cover and lift it straight up.
  6. HP Scanjet 4890 Scanner Glass Underside Cleaning, Clean the glass on the inside: 步骤 6 中的图像 1,1
    • Use only glass cleaner. Avoid abrasives, acetone, benzene, and carbon tetrachloride, all of which can damage the scanner glass. Avoid isopropyl alcohol because it can leave streaks on the glass.
    • Do not spray the glass cleaner directly on the glass and do not allow the cleaner to seep between the glass and the plastic. If liquid gets between the glass and the plastic it could stain the calibration strip (marked) and render the scanner useless.
    • Dust will immediately begin accumulating in your scanner now that the top cover is off. Minimize the time the scanner base is exposed.
    • Beware of static discharge from your fingers, hand, or tools that can damage the circuit boards inside the scanner.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 31
总计 2,111
