跳转到主内容
HP Probook 4425s Hard Drive Replacement
你所需要的
  1. HP Probook 4425s Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 HP Probook 4425s Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Turn the laptop off.
    • Flip the laptop over.
  2. HP Probook 4425s Hard Drive Replacement: 步骤 2 中的图像 1,2 HP Probook 4425s Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Remove the battery.
  3. HP Probook 4425s Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Remove the four 3 mm Phillips head screws that secure the switch cover in place.
  4. HP Probook 4425s Hard Drive Replacement: 步骤 4 中的图像 1,2 HP Probook 4425s Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Flip over and open the laptop.
    • Remove the now loosened cover by grabbing both sides and sliding up.
    • Remove the four 3mm Phillips head black screws directly above the keyboard.
  5. HP Probook 4425s Hard Drive Replacement: 步骤 5 中的图像 1,2 HP Probook 4425s Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Carefully remove the keyboard by sliding it up towards the screen of the computer in order to release the keyboard ribbon cable.
  6. HP Probook 4425s Hard Drive Replacement: 步骤 6 中的图像 1,3 HP Probook 4425s Hard Drive Replacement: 步骤 6 中的图像 2,3 HP Probook 4425s Hard Drive Replacement: 步骤 6 中的图像 3,3
    • Remove the three black 3 mm Phillips head screws from the under the keyboard that are directly above the mouse pad.
    • Carefully remove the mouse pad.
  7. HP Probook 4425s Hard Drive Replacement: 步骤 7 中的图像 1,2 HP Probook 4425s Hard Drive Replacement: 步骤 7 中的图像 2,2
    • The hard drive should be located on the right side of the laptop under the mouse pad.
    • Remove the two black 2 mm Phillips screws holding the hard drive in place on the left side, and remove the larger Phillips head screw on the right side of the hard drive.
  8. HP Probook 4425s Hard Drive Replacement: 步骤 8 中的图像 1,2 HP Probook 4425s Hard Drive Replacement: 步骤 8 中的图像 2,2
    • Remove the hard drive.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 1,439
