跳转到主内容
加入维修社区 - 创建账户
HP ProBook 4740s RAM Replacement
你所需要的
  1. HP ProBook 4740s RAM Replacement, Removing the battery and backplate: 步骤 1 中的图像 1,2 HP ProBook 4740s RAM Replacement, Removing the battery and backplate: 步骤 1 中的图像 2,2
    • Hold in both "levers" so the battery pops out of place. Do this again to remove the backplate.
  2. HP ProBook 4740s RAM Replacement, Removing the old RAM: 步骤 2 中的图像 1,3 HP ProBook 4740s RAM Replacement, Removing the old RAM: 步骤 2 中的图像 2,3 HP ProBook 4740s RAM Replacement, Removing the old RAM: 步骤 2 中的图像 3,3
    • Press on both clasps outwards so that the stick of RAM lifts up out of place. Then, simply remove it.
  3. HP ProBook 4740s RAM Replacement, Installing the new RAM: 步骤 3 中的图像 1,1
    • Take a replacemnt stick of RAM, place it in the slot and push down until it clicks into place.
  4. HP ProBook 4740s RAM Replacement, Installing the Backplate and battery: 步骤 4 中的图像 1,2 HP ProBook 4740s RAM Replacement, Installing the Backplate and battery: 步骤 4 中的图像 2,2
    • Simply slide the backplate into place, from the bottom end to the top end of the laptop. Then, take the battery and push until it clicks into place.
结论
Easy replacemnt of a faulty RAM stick. Same instructions apply when upgrading.
另外一个人完成了本指南。
Mevaa
于07/16/23注册
109 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 10
过去 30 天: 49
总计 367
