跳转到主内容
HP ProBook 455 G1 Hard Drive Replacement
你所需要的
  1. HP ProBook 455 G1 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
    • Before removing the battery, make sure that the computer is turned off and that the power cord is not plugged into the computer.
  2. HP ProBook 455 G1 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the two battery release latches towards the center of the laptop to release the battery.
  3. HP ProBook 455 G1 Hard Drive Replacement: 步骤 3 中的图像 1,2 HP ProBook 455 G1 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Tilt the battery upward.
    • Remove it from the laptop.
  4. HP ProBook 455 G1 Hard Drive Replacement, Service Panel: 步骤 4 中的图像 1,1
    • Slide the two release latches that were mentioned in the battery removal process to release the service panel.
  5. HP ProBook 455 G1 Hard Drive Replacement: 步骤 5 中的图像 1,2 HP ProBook 455 G1 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Slide the service panel toward you using your thumbs.
    • Lift it to remove the panel and reveal inner components of the computer.
  6. HP ProBook 455 G1 Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,2 HP ProBook 455 G1 Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 2,2
    • Using a Phillips #0 Screwdriver, remove the four Phillips 3 mm screws that secure the hard drive into the computer.
  7. HP ProBook 455 G1 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Pull the hard drive cover tab to the left in order to disconnect the hard drive from the computer.
  8. HP ProBook 455 G1 Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Finally, using the same tab, lift the hard drive out of the hard drive port.
结论
7等其他人完成本指南。
Bailey Brammer
于03/18/18注册
343 声望
撰写一个指南
团队
Baylor, Team S5-G1, Williams Spring 2018 Baylor, Team S5-G1, Williams Spring 2018 的会员
BU-WILLIAMS-S18S5G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 33
总计 7,307
