跳转到主内容
HP ProBook 455 G1 DVD/CD Drive Replacement
你所需要的
  1. HP ProBook 455 G1 DVD/CD Drive  Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
    • Before removing the battery, make sure that the computer is turned off and that the power cord is not plugged into the computer.
  2. HP ProBook 455 G1 DVD/CD Drive  Replacement: 步骤 2 中的图像 1,1
    • Slide the two battery release latches towards the center of the laptop to release the battery.
  3. HP ProBook 455 G1 DVD/CD Drive  Replacement: 步骤 3 中的图像 1,2 HP ProBook 455 G1 DVD/CD Drive  Replacement: 步骤 3 中的图像 2,2
    • Tilt the battery upward.
    • Remove it from the laptop.
  4. HP ProBook 455 G1 DVD/CD Drive  Replacement, Service Panel: 步骤 4 中的图像 1,1
    • Slide the two release latches that were mentioned in the battery removal process to release the service panel.
  5. HP ProBook 455 G1 DVD/CD Drive  Replacement: 步骤 5 中的图像 1,2 HP ProBook 455 G1 DVD/CD Drive  Replacement: 步骤 5 中的图像 2,2
    • Slide the service panel toward you using your thumbs.
    • Lift it to remove the panel and reveal inner components of the computer.
  6. HP ProBook 455 G1 DVD/CD Drive  Replacement, DVD/CD Drive: 步骤 6 中的图像 1,2 HP ProBook 455 G1 DVD/CD Drive  Replacement, DVD/CD Drive: 步骤 6 中的图像 2,2
    • Using a Phillips P0 Screwdriver, remove the 6 millimeter screw that secures the DVD/CD drive to the computer.
    • It will be located in the upper left section of the computer, housed in a small square hole in the computer frame.
    • The Phillips head screwdriver is the screwdriver with a "+" shaped tip. P0 refers to the name/size of this particular Phillips head screwdriver.
  7. HP ProBook 455 G1 DVD/CD Drive  Replacement: 步骤 7 中的图像 1,1
    • Using the screwdriver, gently push the silver tab that the screw secured to the left to release the DVD/CD drive from the computer.
  8. HP ProBook 455 G1 DVD/CD Drive  Replacement: 步骤 8 中的图像 1,1
    • The DVD/CD drive will be extended from the side of the laptop. Slowly remove it from the computer.
结论
Jennifer Sexton
于03/18/18注册
649 声望
创作了4篇指南
团队
Baylor, Team S5-G1, Williams Spring 2018 Baylor, Team S5-G1, Williams Spring 2018 的会员
BU-WILLIAMS-S18S5G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 971
