跳转到主内容
HP ProBook 4540s WLAN Module Replacement
你所需要的
  1. HP ProBook 4540s WLAN Module Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s WLAN Module Replacement, Bottom Door: 步骤 2 中的图像 1,1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
  3. HP ProBook 4540s WLAN Module Replacement, WLAN Module: 步骤 3 中的图像 1,2 HP ProBook 4540s WLAN Module Replacement, WLAN Module: 步骤 3 中的图像 2,2
    • Disconnect the antenna cables from their terminals in the WLAN module.
    • One cable is attached to the Auxiliary ("Aux") terminal, represented with a blue wire. The other cable is connected to the Main terminal which is usually represented with a red wire. These wires can be seen in little windows beside the component.
  4. HP ProBook 4540s WLAN Module Replacement: 步骤 4 中的图像 1,2 HP ProBook 4540s WLAN Module Replacement: 步骤 4 中的图像 2,2
    • Unscrew two 3.0 mm Phillips PM2.0x3.0 screw securing the module to the computer.
    • The edge of the module that is opposite of the slot is risen away from the computer.
    • Gently lift and remove the module.
结论
2等其他人完成本指南。
Amber Schindler
于10/26/16注册
1,027 声望
创作了6篇指南
团队
UW Tacoma, Team 1-5, Rose Fall 2016 UW Tacoma, Team 1-5, Rose Fall 2016 的会员
UWT-ROSE-F16S1G5
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 1,801
