跳转到主内容
HP ProBook 4540s Back Door Replacement
你所需要的
  1. HP ProBook 4540s Back Door Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s Back Door Replacement, Bottom Door: 步骤 2 中的图像 1,1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
结论
3等其他人完成本指南。
Amber Schindler
于10/26/16注册
1,027 声望
创作了6篇指南
团队
UW Tacoma, Team 1-5, Rose Fall 2016 UW Tacoma, Team 1-5, Rose Fall 2016 的会员
UWT-ROSE-F16S1G5
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 34
总计 2,051
