跳转到主内容
HP ProBook 4530s WiFi Card Replacement
你所需要的
  1. HP ProBook 4530s WiFi Card Replacement, Introduction: 步骤 1 中的图像 1,2 HP ProBook 4530s WiFi Card Replacement, Introduction: 步骤 1 中的图像 2,2
    • Start by flipping over the laptop onto its back.
  2. HP ProBook 4530s WiFi Card Replacement, Battery Removal: 步骤 2 中的图像 1,1
    • Push both switches inward. The battery should pop out a slight amount.
    • Pull out the battery.
  3. HP ProBook 4530s WiFi Card Replacement, Back Panel Removal: 步骤 3 中的图像 1,1
    • Press on both of the battery switches then push on the back panel forward.
    • It should pop out slightly.
    • Lift and slide the panel off.
  4. HP ProBook 4530s WiFi Card Replacement, Connector Removal: 步骤 4 中的图像 1,2 HP ProBook 4530s WiFi Card Replacement, Connector Removal: 步骤 4 中的图像 2,2
    • Locate the WiFi card outlined in red.
    • The golden connectors will need to be popped off. They are marked in blue.
    • Be very careful. If these connectors break, you will have to buy entirely new wires and connectors.
    • Use a nail, a flat-head screwdriver, anything that will be able to pop off the connector gently.
  5. HP ProBook 4530s WiFi Card Replacement, Card Removal: 步骤 5 中的图像 1,3 HP ProBook 4530s WiFi Card Replacement, Card Removal: 步骤 5 中的图像 2,3 HP ProBook 4530s WiFi Card Replacement, Card Removal: 步骤 5 中的图像 3,3
    • Remove the two screws that secure the card down.
    • The card should pop up at a 45 degree angle.
    • Pull the card straight out.
结论
6等其他人完成本指南。
Drew Canada
于04/03/18注册
1,433 声望
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 30
总计 3,906
