跳转到主内容
加入维修社区 - 创建账户
HP ProBook 4530s RAM Replacement
  1. HP ProBook 4530s RAM Replacement, Introduction: 步骤 1 中的图像 1,1
    • Start by flipping the laptop over onto its back.
  2. HP ProBook 4530s RAM Replacement, Battery Removal: 步骤 2 中的图像 1,1
    • Press in on both sides, the switches will release the battery.
    • The battery will pop out slightly, allowing you to pull it out.
  3. HP ProBook 4530s RAM Replacement, Bottom Panel Removal: 步骤 3 中的图像 1,1
    • Press in on both switches, while pushing onto the plastic panel behind them.
    • The panel should slide out.
  4. HP ProBook 4530s RAM Replacement, Locate and Disassemble: 步骤 4 中的图像 1,3 HP ProBook 4530s RAM Replacement, Locate and Disassemble: 步骤 4 中的图像 2,3 HP ProBook 4530s RAM Replacement, Locate and Disassemble: 步骤 4 中的图像 3,3
    • Locate the RAM slightly to the center-left.
    • Press outward on the metal retention arms for the RAM.
    • The RAM should pop upward slightly.
  5. HP ProBook 4530s RAM Replacement, RAM Removal: 步骤 5 中的图像 1,1
    • Grab the RAM gently and remove at a 45 Degree angle.
结论
6等其他人完成本指南。
Drew Canada
于04/03/18注册
1,490 声望
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 45
总计 3,629
