跳转到主内容
HP ProBook 4530s Hard Drive Replacement
你所需要的
  1. HP ProBook 4530s Hard Drive Replacement, Introduction: 步骤 1 中的图像 1,2 HP ProBook 4530s Hard Drive Replacement, Introduction: 步骤 1 中的图像 2,2
    • Start by flipping over the laptop onto its back.
  2. HP ProBook 4530s Hard Drive Replacement, Battery Removal: 步骤 2 中的图像 1,2 HP ProBook 4530s Hard Drive Replacement, Battery Removal: 步骤 2 中的图像 2,2
    • Press inward on the two switches.
    • The battery should pop out slightly.
    • Remove the battery.
  3. HP ProBook 4530s Hard Drive Replacement, Back Panel Removal: 步骤 3 中的图像 1,2 HP ProBook 4530s Hard Drive Replacement, Back Panel Removal: 步骤 3 中的图像 2,2
    • Press inward on both switches while pushing the center panel away from you. It should slide slightly backwards.
    • Release the switches.
    • Slide the panel the rest of the way out.
  4. HP ProBook 4530s Hard Drive Replacement, Removing HDD: 步骤 4 中的图像 1,2 HP ProBook 4530s Hard Drive Replacement, Removing HDD: 步骤 4 中的图像 2,2
    • Unscrew the four screws located on the edges of the base.
    • Lift enough on the right side of the HDD to make it over the plastic paneling.
    • Pull outward.
  5. HP ProBook 4530s Hard Drive Replacement, Removing HDD from Base: 步骤 5 中的图像 1,3 HP ProBook 4530s Hard Drive Replacement, Removing HDD from Base: 步骤 5 中的图像 2,3 HP ProBook 4530s Hard Drive Replacement, Removing HDD from Base: 步骤 5 中的图像 3,3
    • Remove the adhesive from the protective covering over the HDD.
    • Remove the four screws around the edges of the metal base.
    • Pull out the HDD from the base.
  6. HP ProBook 4530s Hard Drive Replacement, Conclusion: 步骤 6 中的图像 1,1
    • Insert the new HDD or SSD.
结论
8等其他人完成本指南。
Drew Canada
于04/03/18注册
1,370 声望
创作了4篇指南
2条评论
Clear and easy instructions. It’s nice to encounter a computer with such easy access to the internals.
Lensyl Urbano - 回复
You have saved me time and money from going to my engineer to help me out. Thank you.
Mercy Ayinde - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 21
过去 30 天: 79
总计 12,250
