跳转到主内容
简介
"Prerequisite Only"
Replace the HP ProBook 4520s switch cover as a prerequisite for other guides.
配件
没有特定配件。
  1. Flip the 4520s upside-down with the front toward you. Push the two latches below the battery inwards at the same time.
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
  2. Remove the battery by holding the latches and sliding the battery away from you.
    • Remove the battery by holding the latches and sliding the battery away from you.
  3. Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located. Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
  4. Flip the 4520s over and rotate it so the back is facing you. Use a metal spudger to peel off two rubber caps located on either side of the battery port.
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
  5. Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
  6. Rotate the 4520s and then open it with the screen facing you. The switch cover is located above the keyboard.  Push the switch cover away from you until it comes loose from the 4520s. Lift the switch cover away from the 4520s and set it aside.
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
结论
Robert Spencer Harrison
于2016年09月21日注册
947 信誉积分
创作了4篇指南
团队
UC Davis, Team 1-3, Oliver Fall 2016 UC Davis, Team 1-3, Oliver Fall 2016 的会员
UCD-OLIVER-F16S1G3
5 名成员
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 144
