跳转到主内容
HP ProBook 4520s Screen Replacement
你所需要的
  1. HP ProBook 4520s Screen Replacement, Battery: 步骤 1 中的图像 1,2 HP ProBook 4520s Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
  2. HP ProBook 4520s Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by holding the latches and sliding the battery away from you.
  3. HP ProBook 4520s Screen Replacement, Switch Cover: 步骤 3 中的图像 1,2 HP ProBook 4520s Screen Replacement, Switch Cover: 步骤 3 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
  4. HP ProBook 4520s Screen Replacement: 步骤 4 中的图像 1,2 HP ProBook 4520s Screen Replacement: 步骤 4 中的图像 2,2
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
  5. HP ProBook 4520s Screen Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
  6. HP ProBook 4520s Screen Replacement: 步骤 6 中的图像 1,3 HP ProBook 4520s Screen Replacement: 步骤 6 中的图像 2,3 HP ProBook 4520s Screen Replacement: 步骤 6 中的图像 3,3
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
  7. HP ProBook 4520s Screen Replacement, Screen: 步骤 7 中的图像 1,2 HP ProBook 4520s Screen Replacement, Screen: 步骤 7 中的图像 2,2
    • Use a metal spudger to remove four rubber caps at the bottom of the screen border.
  8. HP ProBook 4520s Screen Replacement: 步骤 8 中的图像 1,2 HP ProBook 4520s Screen Replacement: 步骤 8 中的图像 2,2
    • Use a Torx (T9) head screwdriver to remove the four 5mm screws beneath the rubber caps.
  9. HP ProBook 4520s Screen Replacement: 步骤 9 中的图像 1,3 HP ProBook 4520s Screen Replacement: 步骤 9 中的图像 2,3 HP ProBook 4520s Screen Replacement: 步骤 9 中的图像 3,3
    • Pry open the tabs behind the border of the screen using a metal spudger.
    • Set the border of the screen aside.
  10. HP ProBook 4520s Screen Replacement: 步骤 10 中的图像 1,2 HP ProBook 4520s Screen Replacement: 步骤 10 中的图像 2,2
    • Use a Torx (T9) head screwdriver to remove two 5mm screws above the screen, and two more screws below it.
    • The bottom set of screws is installed on the innermost screw holes.
  11. HP ProBook 4520s Screen Replacement: 步骤 11 中的图像 1,1
    • Above the screen is a bronze port with a cable connected to it. Disconnect the cable using a metal spudger or your finger.
  12. HP ProBook 4520s Screen Replacement: 步骤 12 中的图像 1,1
    • Gently push the back cover away.
  13. HP ProBook 4520s Screen Replacement: 步骤 13 中的图像 1,3 HP ProBook 4520s Screen Replacement: 步骤 13 中的图像 2,3 HP ProBook 4520s Screen Replacement: 步骤 13 中的图像 3,3
    • Use a Phillips (PH1) head screwdriver to remove eight 2mm screws from the screen. Four of the screws will be on the left side and four will be on the right.
    • Place the screen face down.
  14. HP ProBook 4520s Screen Replacement: 步骤 14 中的图像 1,3 HP ProBook 4520s Screen Replacement: 步骤 14 中的图像 2,3 HP ProBook 4520s Screen Replacement: 步骤 14 中的图像 3,3
    • Peel the ribbon cable away from the screen.
  15. HP ProBook 4520s Screen Replacement: 步骤 15 中的图像 1,2 HP ProBook 4520s Screen Replacement: 步骤 15 中的图像 2,2
    • To open the clamp for the ribbon cable, use a spudger to pry up the metal bar securing it to the screen.
    • Disconnect the cable after freeing it from the metal bar
结论
6等其他人完成本指南。
团队
UC Davis, Team 1-3, Oliver Fall 2016 UC Davis, Team 1-3, Oliver Fall 2016 的会员
UCD-OLIVER-F16S1G3
5 名成员
创作了8篇指南
2条评论
I need back cover hp i5 probook 4520s
amir86216 - 回复
I need speakers hp probook 4520s i5
Osagie Rmd - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 27
总计 6,088
