跳转到主内容
HP ProBook 4520s Hard Drive Replacement
你所需要的
  1. HP ProBook 4520s Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 HP ProBook 4520s Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
  2. HP ProBook 4520s Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by holding the latches and sliding the battery away from you.
  3. HP ProBook 4520s Hard Drive Replacement, Switch Cover: 步骤 3 中的图像 1,2 HP ProBook 4520s Hard Drive Replacement, Switch Cover: 步骤 3 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
  4. HP ProBook 4520s Hard Drive Replacement: 步骤 4 中的图像 1,2 HP ProBook 4520s Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
  5. HP ProBook 4520s Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
  6. HP ProBook 4520s Hard Drive Replacement: 步骤 6 中的图像 1,3 HP ProBook 4520s Hard Drive Replacement: 步骤 6 中的图像 2,3 HP ProBook 4520s Hard Drive Replacement: 步骤 6 中的图像 3,3
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
  7. HP ProBook 4520s Hard Drive Replacement, Keyboard: 步骤 7 中的图像 1,2 HP ProBook 4520s Hard Drive Replacement, Keyboard: 步骤 7 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
  8. HP ProBook 4520s Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Slide the keyboard panel away from you to free it from the 4520s.
    • Do not yank the keyboard panel away from the 4520s. This may damage the cable.
    Does keyboard slide away or to right/left? thought it was to the right.
    Heidi Bell - 回复
    Keyboard goes directly away
    Robert Spencer Harrison -
  9. HP ProBook 4520s Hard Drive Replacement: 步骤 9 中的图像 1,2 HP ProBook 4520s Hard Drive Replacement: 步骤 9 中的图像 2,2
    • Gently raise up the keyboard and flip it over to reveal a ribbon cable.
    • Release the ribbon cable by carefully lifting the black tab upwards, one side at a time.
    • Remove the cable and lift the keyboard panel up. Set it aside.
    • When reassembling, feed the ribbon cable into the port. Press down on the tab to pinch the cable in place.
  10. HP ProBook 4520s Hard Drive Replacement, Palm Rest: 步骤 10 中的图像 1,2 HP ProBook 4520s Hard Drive Replacement, Palm Rest: 步骤 10 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the three 3mm screws along the top of the palm rest.
  11. HP ProBook 4520s Hard Drive Replacement: 步骤 11 中的图像 1,2 HP ProBook 4520s Hard Drive Replacement: 步骤 11 中的图像 2,2
    • Slide the palm rest to the right to release it and then rotate it back gently.
    • Do not yank the palm rest away from the 4520s. This may damage the cable.
  12. HP ProBook 4520s Hard Drive Replacement: 步骤 12 中的图像 1,2 HP ProBook 4520s Hard Drive Replacement: 步骤 12 中的图像 2,2
    • Release the ribbon cable by opening the black hinge on the port using a spudger.
    • Remove the cable and set the palm rest aside.
  13. HP ProBook 4520s Hard Drive Replacement, Hard Drive: 步骤 13 中的图像 1,3 HP ProBook 4520s Hard Drive Replacement, Hard Drive: 步骤 13 中的图像 2,3 HP ProBook 4520s Hard Drive Replacement, Hard Drive: 步骤 13 中的图像 3,3
    • The hard drive is contained in the housing on the lower right.
    • Remove two 5mm screws on the left using a Phillips #1 screwdriver.
    • Fully loosen the captive screw on the right using a Phillips #1 screwdriver.
  14. HP ProBook 4520s Hard Drive Replacement: 步骤 14 中的图像 1,2 HP ProBook 4520s Hard Drive Replacement: 步骤 14 中的图像 2,2
    • Disconnect the hard drive by pulling the tab to the right.
    • Lift the housing out from the 4520s.
  15. HP ProBook 4520s Hard Drive Replacement: 步骤 15 中的图像 1,2 HP ProBook 4520s Hard Drive Replacement: 步骤 15 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the four 3mm screws on the sides of the housing.
  16. HP ProBook 4520s Hard Drive Replacement: 步骤 16 中的图像 1,1
    • Lift the housing away from the hard drive.
    • The hard drive is 2.5".
结论
53等其他人完成本指南。
May Lin
于09/21/16注册
849 声望
撰写一个指南
团队
UC Davis, Team 1-3, Oliver Fall 2016 UC Davis, Team 1-3, Oliver Fall 2016 的会员
UCD-OLIVER-F16S1G3
5 名成员
创作了8篇指南
5条评论
is it 2.5" HDD ?
Bf Soldier - 回复
Yes. I should have included that.
Thank you so much lol
You taught me that i didn’t have to throw and break this darn machine to get the hard drive out :P
M
Maria Sergent - 回复
Thank you!
This guide works well for the 4320s as well, though there are a few small differences.
The battery compartment has 4 screws and there are none on the back.
The keyboard is held by 4 screws.
The touchpad has the same type of connector as the keyboard.
The hard drive cage is held by a #1 Philips and two #0 Philips instead of #1.
Carl - 回复
Thank you kindly for such a easy to follow step by step tutorial. Never thought this rooky would be able to repair my own laptop
You guys rock
Eugene B - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 42
过去 30 天: 125
总计 38,572
