跳转到主内容
HP ProBook 450 G7 Battery Replacement
你所需要的
  1. HP ProBook 450 G7 Battery Replacement, Remove Back: 步骤 1 中的图像 1,3 HP ProBook 450 G7 Battery Replacement, Remove Back: 步骤 1 中的图像 2,3 HP ProBook 450 G7 Battery Replacement, Remove Back: 步骤 1 中的图像 3,3
    • 7 P1 screws, green are removed the rest are retained
    • Start with the hinge useing picks to slip inbetween the plastic and a spudger to pry apart
    • The Ethernet jack is secured inside, do not try to remove
  2. HP ProBook 450 G7 Battery Replacement, Replace the battery: 步骤 2 中的图像 1,1
    • Remove the two P1 Screws and lift the battery out. being carefull to apply even presure across the battery
结论
另外一个人完成了本指南。
Conor Bone
于11/04/20注册
156 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 27
过去 30 天: 118
总计 3,008
