跳转到主内容
HP ProBook 4320t Speakers Replacement Guide
你所需要的
  1. HP ProBook 4320t Speakers Replacement Guide, Battery Removal: 步骤 1 中的图像 1,2 HP ProBook 4320t Speakers Replacement Guide, Battery Removal: 步骤 1 中的图像 2,2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Speakers Replacement Guide, Screws: 步骤 2 中的图像 1,2 HP ProBook 4320t Speakers Replacement Guide, Screws: 步骤 2 中的图像 2,2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Speakers Replacement Guide, Flip: 步骤 3 中的图像 1,1
    • Flip laptop over and open it.
  4. HP ProBook 4320t Speakers Replacement Guide, Push N Lift: 步骤 4 中的图像 1,1
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Speakers Replacement Guide, Unscrewing: 步骤 5 中的图像 1,1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Speakers Replacement Guide, Careful Now: 步骤 6 中的图像 1,2 HP ProBook 4320t Speakers Replacement Guide, Careful Now: 步骤 6 中的图像 2,2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Speakers Replacement Guide, Disconnect Wire: 步骤 7 中的图像 1,1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  8. HP ProBook 4320t Speakers Replacement Guide, Speakers: 步骤 8 中的图像 1,1
    • Use the black spudger tool to lift the white, black, and red ribbon cable connector up so that it is disconnected.
  9. HP ProBook 4320t Speakers Replacement Guide: 步骤 9 中的图像 1,1
    • Unscrew the two (2.5 mm Phillips) screws (located on the upper most part of the computer) holding the speakers in.
  10. HP ProBook 4320t Speakers Replacement Guide: 步骤 10 中的图像 1,1
    • Using the black spudger tool, gently pry off the right speaker.
    • Be careful to not break the cord.
  11. HP ProBook 4320t Speakers Replacement Guide: 步骤 11 中的图像 1,1
    • Remove the cords from the retention clips.
  12. HP ProBook 4320t Speakers Replacement Guide: 步骤 12 中的图像 1,1
    • Remove the left speaker as completed in step #10.
结论
另外一个人完成了本指南。
Eric Markham
于08/29/14注册
227 声望
创作了4篇指南
团队
USF Tampa, Team 9-5, Blackwell Fall 2014 USF Tampa, Team 9-5, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S9G5
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 545
