跳转到主内容
HP ProBook 4320t Clock Battery Replacement Guide
你所需要的
  1. HP ProBook 4320t Clock Battery Replacement Guide, Battery Removal: 步骤 1 中的图像 1,2 HP ProBook 4320t Clock Battery Replacement Guide, Battery Removal: 步骤 1 中的图像 2,2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Clock Battery Replacement Guide, Screws: 步骤 2 中的图像 1,2 HP ProBook 4320t Clock Battery Replacement Guide, Screws: 步骤 2 中的图像 2,2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Clock Battery Replacement Guide, Flip: 步骤 3 中的图像 1,1
    • Flip laptop over and open it.
  4. HP ProBook 4320t Clock Battery Replacement Guide, Push N Lift: 步骤 4 中的图像 1,1
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Clock Battery Replacement Guide, Unscrewing: 步骤 5 中的图像 1,1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Clock Battery Replacement Guide, Careful Now: 步骤 6 中的图像 1,2 HP ProBook 4320t Clock Battery Replacement Guide, Careful Now: 步骤 6 中的图像 2,2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Clock Battery Replacement Guide, Disconnect Wire: 步骤 7 中的图像 1,1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  8. HP ProBook 4320t Clock Battery Replacement Guide, Unscrew: 步骤 8 中的图像 1,1
    • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
  9. HP ProBook 4320t Clock Battery Replacement Guide, Slide the Panel Off: 步骤 9 中的图像 1,1
    • Carefully slide the bottom panel to the right.
    • Keyboard is connected via a wire to the back of the panel.
  10. HP ProBook 4320t Clock Battery Replacement Guide, Lift up Carefully: 步骤 10 中的图像 1,1
    • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
  11. HP ProBook 4320t Clock Battery Replacement Guide, Disconnect Wire: 步骤 11 中的图像 1,1
    • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
  12. HP ProBook 4320t Clock Battery Replacement Guide, Detach Cables: 步骤 12 中的图像 1,1
    • Using the black spudger, detach the two antenna cable connectors leading to the Wi-Fi card (this is to access the clock battery without causing damage to the cords).
  13. HP ProBook 4320t Clock Battery Replacement Guide, Pop it Out: 步骤 13 中的图像 1,1
    • Using your black spudger, gently press down and towards you until the battery slides out.
    • Put new clock battery in and reassemble.
结论
2等其他人完成本指南。
Joshua
于09/23/14注册
134 声望
创作了6篇指南
团队
USF Tampa, Team 9-5, Blackwell Fall 2014 USF Tampa, Team 9-5, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S9G5
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,003
