跳转到主内容
HP Prime Graphing Calculator G8X92A Battery Replacement
你所需要的
  1. HP Prime Graphing Calculator G8X92A Battery Replacement, Prerequisites: 步骤 1 中的图像 1,1
    • Power down the device.
    • Flip the device face side down so the back of the device is facing up.
  2. HP Prime Graphing Calculator G8X92A Battery Replacement, Disassembly: 步骤 2 中的图像 1,3 HP Prime Graphing Calculator G8X92A Battery Replacement, Disassembly: 步骤 2 中的图像 2,3 HP Prime Graphing Calculator G8X92A Battery Replacement, Disassembly: 步骤 2 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove the two 4.5 mm screws securing the battery cover located at the bottom center of the device.
    • Remove the cover.
  3. HP Prime Graphing Calculator G8X92A Battery Replacement, Replacement: 步骤 3 中的图像 1,3 HP Prime Graphing Calculator G8X92A Battery Replacement, Replacement: 步骤 3 中的图像 2,3 HP Prime Graphing Calculator G8X92A Battery Replacement, Replacement: 步骤 3 中的图像 3,3
    • Remove the battery.
结论
To reassemble your calculator, follow these instructions in reverse order. Power on the Calculator to make sure it works.
3等其他人完成本指南。
2指南评论
The link to the battery in the "what you need" section is not correct. The battery is the same as the Samsung Galaxy S3. It has dimensions of approximately 50mmx63mmx5.5mm, with a 4-terminal connector on the top. it is 3.7VDC/7.4Wh. The one that comes with the calculator is "rated" at 2000mAh (whatever that means these days, as battery specs are often works of fiction).
m_a_s - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 6,715
