跳转到主内容
HP Photosmart c4780 Scanner Glass Assembly Replacement
你所需要的
  1. HP Photosmart c4780 Scanner Glass Assembly Replacement, Outer Shell Disassembly: 步骤 1 中的图像 1,2 HP Photosmart c4780 Scanner Glass Assembly Replacement, Outer Shell Disassembly: 步骤 1 中的图像 2,2
    • Unplug the device from any energy sources.
    • Lift the top cover of the scanner.
    • Use a plastic opening tool to remove the plastic frame surrounding the glass.
  2. HP Photosmart c4780 Scanner Glass Assembly Replacement: 步骤 2 中的图像 1,1
    • Carefully pull the frame away from the glass.
    • If it doesn't remove easily, use the iFixit Opening Tool again to pry stuck sections.
  3. HP Photosmart c4780 Scanner Glass Assembly Replacement: 步骤 3 中的图像 1,1
    • Use a T10 screwdriver to unscrew the two screws that fasten the frame to the printer hood.
  4. HP Photosmart c4780 Scanner Glass Assembly Replacement: 步骤 4 中的图像 1,2 HP Photosmart c4780 Scanner Glass Assembly Replacement: 步骤 4 中的图像 2,2
    • Put your finger behind the panel with the power button.
    • Then, pull the piece outwards.
  5. HP Photosmart c4780 Scanner Glass Assembly Replacement: 步骤 5 中的图像 1,2 HP Photosmart c4780 Scanner Glass Assembly Replacement: 步骤 5 中的图像 2,2
    • Unscrew the screw inside the power button panel space.
    • Then, unscrew the screw that is across the printer slider.
  6. HP Photosmart c4780 Scanner Glass Assembly Replacement: 步骤 6 中的图像 1,1
    • Pull the white circuit board outwards which is located under the small screen.
    • Unplug the small ribbon cable from the circuit board.
    • Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
    • Unplug the small ribbon cable from the circuit board. Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
  7. HP Photosmart c4780 Scanner Glass Assembly Replacement: 步骤 8 中的图像 1,2 HP Photosmart c4780 Scanner Glass Assembly Replacement: 步骤 8 中的图像 2,2
    • Pull the memory card reader's circuit board out.
    • Detach the white wiring connector from the back of the circuit board.
    • You may need to use a finger nail or a plastic opening tool to detach the white wiring connector from the circuit board.
  8. HP Photosmart c4780 Scanner Glass Assembly Replacement: 步骤 9 中的图像 1,2 HP Photosmart c4780 Scanner Glass Assembly Replacement: 步骤 9 中的图像 2,2
    • Put your finger behind the small screen.
    • Then, pull it up.
    • Do not hesitate to use force to remove the TouchSmart panel.
    • Disconnect the ribbon cable from the small screen.
  9. HP Photosmart c4780 Scanner Glass Assembly Replacement: 步骤 10 中的图像 1,1
    • Pull the printer hood upward.
  10. HP Photosmart c4780 Scanner Glass Assembly Replacement, Scanner Glass Assembly: 步骤 11 中的图像 1,2 HP Photosmart c4780 Scanner Glass Assembly Replacement, Scanner Glass Assembly: 步骤 11 中的图像 2,2
    • Lift the scanning lid from the lower portion of the printer hood.
    Remove torx screw on bottom of assembly in corner near touchsmart screen space.
    Jeff - 回复
  11. HP Photosmart c4780 Scanner Glass Assembly Replacement: 步骤 12 中的图像 1,2 HP Photosmart c4780 Scanner Glass Assembly Replacement: 步骤 12 中的图像 2,2
    • Leaving the ribbon connected, lift the sliding scanner off the track.
    • Pull the ribbon cable out of the slot on the scanner circuit board.
    • Insert the scanning piece into the rolling track.
结论
To reassemble the sliding scan piece, follow these instructions in reverse order.
Renee Lamb
于09/26/12注册
235 声望
创作了3篇指南
团队
Cal Poly, Team 2-11, Propen Fall 2012 Cal Poly, Team 2-11, Propen Fall 2012 的会员
CPSU-PROPEN-F12S2G11
4 名成员
创作了6篇指南
一条评论
Where can i buy the scaning piece? Im from Spain.
Bogdan Cosmin - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,505
